WB projects I just watched your latest video
I feel like you haven't run the theoretical numbers to workout about how much electrical power you'll probably need and therefore what components you'll need. Brgwarner has a great tool that you can use to get an idea of the power you'll need ..
1) What engine size do you have
2) What is it's redline
3) What PSI do you want at redline.
In your video you have a 24v 50amp BMS .. 50amps is WAY WAY WAY to low you'll need hundreds and hundreds of constant current amps to get any meaningful power (BOOST) out of such a low Voltage.
