MkngStffAwesome
I'll post where im at .. Im not sure this will ever have an end or actually start but i'll post where im at.
Firstly i Live in New Zealand.. which is a small country and speed limits are relatively low. I currently have a 2006 Suzuki Swift (Manual) which has a 1600cc engine.. It's actually quite good as it is now but the sad thing about it is that, low in the RPM it's rather weak.
I have a friend with the same car and he has "real turbo'd" his car but that has cost him 3 times the purchase price of the car .. sure it goes great and will always be better than an e-turbo But the price is out of the question.. SO an e-turbo would seem to be a good idea since i can do most of it my self and it should offer good bang for that buck.
The swift being a small engine is seemingly ideal to E-tubo because the power requirements will be low, But at the same time size is limited and things like alternator output is tiny so it's all relative.
I have been in the process of e-turboing for a number of years and that has resulted in me chopping and changing over the years as to what i would do. Right now i'm probably not doing the ideal.
MK1
Was to make an ideal system Running on 90ish(22s) volts ( No one should be running 12,24,34,60v ) Using LifePo4 batteries.
I didn't want to run Lipos because my own repeated experience with lipos is they are as bad as they are made out to be on you tube .lol
Buying batteries is always a difficult thing because you don't know if the seller is telling you the truth or not. Most LifePo4 batteries seem to have a constant discharge of 3c So to get 100 Amps you'd need 33ah batteries * 22ish.
I would buy a TD05 with extended tip compressor (GTX3076R GEN 2) .. i did buy this
Considering the size of my engine is 1600cc this is a burst out laughingly large compressor. However it was chosen because i could in theory achieve the results at a low compressor speed. I could not go larger because even this is hard to fit in my engine bay. Also larger ones get crazy expensive.
Based on the BorgWarners excellent tool at 7.5 PSI (1.5) i need to flow 20LBS/ min that is 70,000 RPM
I would buy a TP4070-CM at 1400KV which at 80v is 112,000 RPM ( i did buy this )
I went for 112K RPM because this is the unloaded RPM. This RPM is what you'll get when not compressing any air or spinning the wheel at all. When the motor is trying to compress the air it will be FAR lower than this theoretical number ( it probably wouldn't even get to 70k)
The max rpm for 10 seconds is 75,000 before it explodes so that is ok ( just ) for our target of 70k Also the the max power can be 9kw before overheating.
The power required to compress 20lbs @ 7.5psi according to borgwarners app with a 1600cc motor at 6800 rpm is. 10.43 HP OR 7.8 KW , which our motor and batteries should be ok with. 7800KW / 80v = 97.5amps
This should all work in theory though there are some touch and go parameters.
MK2
After buying the Motor and Compressor and continued research i was scared off with a direct motor shaft to compressor setup. This is because of a number of failed attempts in relation to achieve this by others.. One of the issues is trying to machine the Motors shaft and ensuring that it is machined Perfectly Perfectly True and being able to retain the compressor wheel on. While it is totally possible to machine this perfectly if not it's a disaster and it seems that disaster was pretty common. lol
I also came to the realization that MK! was going to cost a mind blowing amount of money for what is a very cheap car. This is in part because i dont believe i can throw the number of batteries in the boot (trunk) and this car being even remotely legal to dive on the roads here.
So MK2 became all about cost cutting. The biggest problem is the batteries and the cost of them, the storage and charging of them. So I thought to myself lets just bin them all together and Run it off 12v ...12v would create some new problems..
A)@12v 7,800 kw would equal 650 amps..
This is a total joke and so required power had to be reduced (PSI) to a more manageable 400amps or 4,800watts or 6.5ph.. this is good enough for 5psi at 6800rpm.. and it is still possible to provide more boost at lower rpm as power requirements reduce with rpm.
B) Compressor speed was now to slow 12x 1400kv= 16,800rpm. At this point i had already bought this motor.. but even at the highest KV of 3200 x 12 = 38,400rpm is far to far from where were need to be at. SO the only way to get a theoretical speed of 100K plus was to GEAR the motor. This is fine because i already didn't want a direct motor to compressor wheel system anyway. I originally went with a belt drive system but after looking at the numbers, as RPM increase then the torque that could be applied decrease, and as you can bet there are no 70k rpm belts while applying 7hp. I have since moved to metal gears that will be louder and require gear oil but they will work... and i can obviously change the gear ratios.
C) The car would handle the charging like normal but it also meant that when boosting it would also be pulling power from the alternator.
At this point i bought a 3s -16s 400 ESC like ALex had.
The idea wouldn't actually be to power my e-turbo from my tiny tiny 12v lead acid battery but to replace it with Lipo4 ones. The largest i could fit is 100amp ones. which meant the max theoretical current would be 300amps (3600watts) not 400amps.
This is what im in the process of getting made.
You'll notice that this has place for a second motor
MK3
Currently have
3-16s 400 amp ESC
TP4070-CM, 1400KV
TD05 compressor
Housing getting machined
I performed some testing and im very concerned about pulling 300amps and the fire risk that this posses and Alexs blown up ESC too.
Also pulling 300 amps from the same pack that the car is monitoring and the alternator is trying to charge is a questionable idea.
So im almost back where i started except i have bought some parts and obviously need to use them.
So the current idea is to go to 16s with lipos, which is the max the ESC supports this is 60 + ish volts. 60 * 100 = 6KW so thats about what i need even more should be ok form this ESC without explosion's.
I will need to run lipos because LTO and Lifepo4 just doesn't workout no mater how many times i try to make it work.. I will however be under charging the LIPOS and under discharging them and have them in a metal box.
I have actually done a lot with a controller to Run my e-turbo but i also keep chopping and changing with that too.. hes a few pics anyway
MK1
MK2
MK3
Currently have
3-16s 400 amp ESC
TP4070-CM, 1400KV
TD05 compressor
