or 2 beasties of those :
Under $9.50 per cell with busbars, spacers, and metal enclosure. The Headway battery game has just officially gotten better. These modules have 32 headway cells inside and they are configured in 8s4p (24v). All you have to do to convert these into 12v is cut the busbar in the center of the one...
batteryhookup.com
8s4p ... the weight is on 4p here ... IR and discharge rate
(shoot ... and a suitable BMS
per beast module)
EDIT: after looking up the specs of Headway 38120HP cells ... the Batteryhookup picture saying 200A (per cell?!) seems a bit exaggerated!
Just hold off on those 38120hp.. if you look on the internet these don't appear to be as good as the manufactures spec which is <3mohms ... a guy on the internet tested them at 5.5mohms.
i have ordered some A123 AHR32113 because they have been review very well on the internet at 1ohms which is less than their manufactures spec
This coming month i will also order some 38120hp and some A123 26650's
Assuming that the A123 26650 achieve their manufactures spec of 5.25m ohms then these are probably the go (within cylinder LifePo4 chemistry)
That's because they are obviously about 1/2 the length of the others.. But also they can be packed more densely so in my space i can fit 14s4p of 26650 V 14s1p of headway 38120hp's ... the 26650 will give me more capacity and lower resistance.(in therory)
NOW i know this is all based on theory because these none of these cells have been tested by the same person and in the same way.. Im ordering some more test equipment to test the 3 in the same fashion so it's a fair test... After this i'd love to see people buy the same test equipment and test other batteries in the same fashion to build up a DB of appropriate batteries.
EDIT updated 30/08/21 (updated LTO resistance to what Alex tested. I had the capacity wrong for the 26650,s recalculated everything )
A note on LTO's (in theory) (So could be total BS without testing both cells)
32 LTO's in series @ 2.8v = 89.6v
32 LTO's in series with a IR of 0.77 = 24.64m ohms capacity of 18ah
Manufactures Spec that i found said <1mohms so they could be much worse than this example. (update i have since found a few places saying 0.57 and 0.49) ALEX tested them a 0.77 mohms
25 A123 26650 in series @ 3.65= 91.25v
25 in series @ 5.25m ohms = 131.25 capacity of 2.5h
2p 65.625m ohms C = 5ah
4p 32.8125m ohms C =10ah
6p 21.88m ohms C =15ah
Total cells 84 @ 0.076 kg
Total weight 6.384kg (not including fixings)
Volume based on a square 26mm x65mm X 84 = 56,784 square mm
32 LTO @ .8kg= 25.6kg (not including fixings)
Volume based on a square 60mm X 130 X 32 = 249,600 square mm BUT this excludes the terminals on each end which will make them a good deal bigger.
