WB projects
hey everyone! super good news and nice update for you! some issues but some are fixeable and some I can live with it! The bms I bought and blow in like 15min have been refund and replace with an other brand and it work really good with my step up to **charge** the batterys. the only issue I have with this is I'm block to 31.1v for the pack instead of 33.6 full charge. BUT with 30sec of run time I drop to 29.6v and after 2min it goes all the way to 31.1v. So this is super fast for me! The other issues I had was my three phase wires was 8awg. it supposed to be just enough for me! but they become hot enough to get biger one. so im now with 10' of 4awg. Now, Alex suggest me to get capasitor because the motor use to "buck" a little bit and I have consider this solution but I want to try without it. So bigger wire=less chance of voltage drop, so mayyyybe no need to use capasitor (in my case). now my esc was programmed 100% power and the motor still bucking. one thing I realised is my 2 6" 8awg wire from the betterys to the ESC was crazy hot ! So! I supposed that may cause a voltage drop and the ESC cut off because he thincking the batterys is low. I turn down the ESC to 70% (still need to get bigger wires for the battery to the ESC) and now it work like a charm!! So this is a small 20min test I need to make to have good sleep! tomorrow I will try something else and fine tunning it!
I have a friend who ordered a torqamp with the same car I have! will be fun to compare
ps. sorry for my english
