I know that SQCTS and cmoalem have both jumped on board the P2 blower bandwagon and I took advantage of Speedmaster's black Friday sale and ordered one myself. SQCTS already has his running (direct drive) on low power; cmoalem is going the timing belt route. I wanted to start a thread devoted to using this particular head unit.
Here's SQCTS' build thread:
Here's what cmoalem has found out so far regarding the timing belt drive idea:
Let's see which drive method works out the best. I'll probably use my bigger TP Power motor to power this unit and use the LMT motor to power my Vortech.
It Has Begun
Ok I fellow E-Charger comrades, I have startes my build. I chose to go the direct drive route as it just seems the most efficient way of doing it. Below you will find a few pictures of my direct drive setup using the SpeedMaster P-2 supercharger that was recommended to start with and the TP...
www.electrifiedboost.com
And here the latest update:
Particularly interesting for the "belt drive" variant!
So I found the seller boltonbearings UK on ebay and ordered THIS:
1) Timing Belt T5, 5mm pitch, 25mm wide (T5-260 52 teeth)
2) Pulley T5 36T5/12-2
3) Pulley T5 36T5/15-2
4) Pulley T5 36T5/18-2
after a shipping mishap with Royal Mail the guys stood up and sent everything again "registered".
Looky what came today:
View attachment 262View attachment 263View attachment 264View attachment 265
Yes ... the pulleys need machining to accept the 8mm shaft and some holes for the set screws ...
But it WILL be a clean solution!
(unfortunately my AliExpress battery order had to be disputed ... shipping "irregularities" by the seller. Waiting for the money to come back now... then need to pick better seller and order again)
