Hi all - I've been innundated with all kinds of stuff. Life was supposed to ease up by now, but instead things got even more chaotic. But I'm still doing my best to keep up the research on my end. This Black Friday I took advantage of another sale on a P2 supercharger (for those counting at home, I now have 2... for good reason...) I have yet to unbox that thing. What I DID unbox yesterday was the Hobbywing EzRun Max4 ESC. It's rated for 300 amps continuous (2,000 (!) amps peak); but the bummer is it's only good for 50 volts (12s). However, on lower-power applications (say under 600-650 hp), it should be ideal. Also good for multi-compressor setups (that's why I have have two P2 units).
Mine didn't come with a sensor adapter cable (it was supposed to, apparently there was a run of these recently that didn't have them), but I reached out to the company and we'll see what they say. A good test for company support. Even so, I used the LCD programmer, and got it running in a few short minutes. There are a few quirks for our purposes, but there are a few benefits, too. After the VESC nightmare, having both the MGM and now the Hobbywing just working out of the box is a reminder of how things should be. I was running on 8s (my small 6ah lipos); and I saw ~150 amps in a quick test - enough for the blower to blow itself around on the desk - and with the beefy aluminum base, it's about 20 lbs or so.
The best part - it's less than $450 USD; making it less than half as expensive as the small APD ESC (which was rated for 400 amps continuous, but the programming software showed a 300 amp max; though that one was good for 63 volts) and less than a third of the cost of the bigger APD or the MGM.
I'll make some videos on this as soon as I possibly can:
