That is just the thing... Rotrex's are internally geared up already. (His setup is geared up) While I already agreed to that point in the other topic, In this case all of that is moot! How many kits or DIY'ers have
8psi at redline.. and if you take in to account the volume of the piping and intercooler it has to fill we are talking a much higher output at the compressor outlet. (Maybe 10-11psi)
As far as the averave joe being able to replicate it, well all the info is in his thread. It can easily be done... he just spent WAY more than what most of us are willing to.
He'll I'm sure someone out there could go buy a Royobi brushless 1/2 impact and produce boost with it... it would have to be geared in a ridiculous manner as it only spins to 1,400rpm... but it has some decent tq! if you wanted you could buy two and still be around what one TP power motor costs... is this realistic... not really... but it is something to note about selecting a motor to produce the desired results and what it costs and what gearing if any needs to be implemented.
What I am getting at is an exercise in finding the right combination. What is the point in having a high rpm motor spinning a compressor wheel that it doesn't have the tq/power to spin effectively...
Granted Alex had good results form direct driving the Vortech with the Tp power...
But would that setup be better with the LMT torqstar3?
What other motors are out there, where are their technical data sheets?
As Diyers we are always looking to get the best results with the compromise of being frugal. I'm not trying to argue with anyone here at all! There is a wealth of information here and some people with the means to test, write code, 3d print, Ect.. That all amounts to amazing insight and development of a system many say isn't worth the time, money, or energy.
I have seen great things so far on this forum from its members, and I don't think I have read through half of what is on here.
The BIG difference is :
when you drive a charger from the crankshaft then you NEED to overdrive it to get into the efficient area of the map!
