Ok I fellow E-Charger comrades, I have startes my build. I chose to go the direct drive route as it just seems the most efficient way of doing it.
Below you will find a few pictures of my direct drive setup using the SpeedMaster P-2 supercharger that was recommended to start with and the TP Power 5870 750KV motor.
This wasn't an easy thing to do without a lathe or CNC. I had do it with a good ole 4.5" grinder, files and a drill press and a ton of bad words.
Went thru about 3 different ways of doing it, all of them would have and can work. In the pictures below you will find a plate I made to mount it and was going to use the same 3 mounting holes as the factory spinal cover however after some mishap and bad choices it ending up bing about 1.25" taller than I think I could fit in my space in the car and would've had buy longer screws which is not and issued just not what I wanted. So after all the work making the plate I decided on first thought of just using the spinal cover. Which still about .75" taller than I had planned, but it still should fit without to much fuss.
Testing on the beach will start this weekend
