MkngStffAwesome
I decided to start a new thread since i think things are alot more clear
I guess this is the first video of alot
Did it work to remove the "rev hang?"
Yeah rev hang is unrelated to the E-Turbo.. but the piggie back controller is not as that is required for the E-turbo. So im making indirect progress. I have also ordered my Wide Band O2 sensor. After that is installed i then can get back to spending money on the actual E-Turbo..Severely retarded timing can also cause heat issues. At least it's not a critical issue. Any progress on the e-turbo? (I honestly hate calling it that, but it's just so easy to write...)
I had hoped to retard the timing massively but unfortunately the stock ECU doesn't like a Massive retard and throws a error code.
I could trick the ECU into thinking there is very little air coming through and so it would mostly cut fuel.. im not sure if that would work though cos it might be running in closed loop mode.. And this idea should be sending through unburnt fuel, which might be a bad idea.
